Please help me on finding Php press release script
I am looking for a script that allows people to upload their press releases into a category. Anyone knows the php press release script? How can I have it?
It is not available for free. You have to buy the script or template from web sites. There are numerous .php based sites which sell this type of script. You can choose from their ready- made models or order a customized model according to your requirement.
http://www.pressreleasescript.com/
I found this site with rich collected works for press releases.
Here are some of the free and paid news scripts for news publishing that allows you to upload your articles by category:
This news publishing script is an advanced News Publishing and Management System. It was designed to make the publishing of news less complicated and without any programming. You can easily and quickly add news using the WYSIWYG editor or What You See Is What You Get. Among its features include the ability to classify your news in infinite categories, can easily be installed and use, add infinite articles, and more. Costs $20.
This script allows you to make money with Google Adsense, Affiliates and Advertisements and can handle thousands of press releases. It includes 12 professionally designed themes that can be used to change the look of the website with just one click. Among its features include the support for unlimited number of content contributors, flawless management that lets you publish and approve content all at the same time, and more. Costs $99.
It is a less complicated news publishing script that saves the data in a flat file. When you are logged in as the admin, the script allows you to add, edit [wysiwyg], and delete news entries. This is a free news publishing script.
Aside from these scripts, also visit PHP Press Release Scripts to see more of these news publishing scripts.
