Hello techyv.com!
I have here a laptop and Xperia X10 cellphone. My laptop had been working slow for few days last year, and it seemed it got better when I defrag it. Now my Xperia X10 seems like it is getting slower and slower, So please help me how to defrag android system if it would help in repairing my phone.
Please help me how to defrag android system
Defragment helps your operating system maintain a high level of performance. T
o do this, it Defrags the operating system and memory.
Many defragment apps are available for the Android system.
Android Defrag is the best defragment application for the Android.
It defrays its OS and makes your phone run very quickly.
Download it here.
There is also Defrag+.
Download now
Unfortunately, like with iOS devices, you don’t defrag an Android device because they are not using a normal hard drive for their internal storage. Defragmenting a storage device like IDE and SATA drives is designed or intended for computers only. If you try this on your iOS or Android device, you might end up with a broken Smartphone.
If your phone is getting slower and slower every day, the best solution is to clean it. Like with a normal computer, a Smartphone is like a small computer that creates temporary files as it operates. These temporary files pile up as you use it making the device slow in the long run.
In computers, you fix this problem by cleaning the system from unwanted files and defragmenting the hard drive to improve data transfer again. But with Smartphones, you don’t do these. Cleaning is enough. To fix the slowness of your phone, download Clean Master and install it on your phone.
