Licensing Error on my Adobe Flash Pro
I am having a problem with my adobe flash professional. I bought an original copy of it but after 2 weeks of using it this error suddenly comes out.
Dear Marcus Shawn,
This error “Licensing has stopped working” in Adobe Flash Professional usually occurred time to time. There are some steps for fixing that issue.
Step 1: Do licensing service update.
Step 2: Set FLEXnet licensing service to manual and start service again.
Step 3: Rename FLEXnet data folder.
Step 4: Reset your permissions in licensing service data folder.
Step 5: Reset your permissions in adobe PCD folder.
Step 6: Remove SQLite journaling file.
Other solution: Contact adobe technical support team.
Note: Perform the solutions mentioned above in order. Do not continue to next solution, if a prior solution resolves the issue.
For further help, you can check this link:
Take Care.
Kate
Hi Marcus,
Please find below solutions for your reference. Follow these steps.
Hope this could helps. Have a nice day…
