Please help me with my problem in the Links using Lotus Notes.
Hi! I am using Lotus Notes and I have some difficulties with the links: when I change the source files of the link, the change does not appear in Lotus Notes. While testing Lotus Notes, I highlighted a section of a Microsoft Word file and pasted it into Lotus Notes using the Paste Special-Create Link operation. If I make any change in the Word document: it will only be reflected if it’s in the highlighted section; if the change is made anywhere in the Word document, outside this section, the change will be not reflected in the Lotus Notes file. Sometimes, it happens that Lotus Notes can’t find the source document at all, if it’s been changed. Does anyone know if there’s a way to create a link to an entire source document, so every change made in it to reflect in the Lotus Notes?
