Please help me reduce blocks for bitmap for ie
Hello techyv.com!
I have been downloading a lot of images for my project, and I have seen a good image via internet explorer. The thing is it is a bitmap image, and its kind of blocky. Please help me how to reduce this blocky image for bitmap for ie. My Laptop is HP Windows Vista. Thanks!
Answered By 0 points N/A #130553
See the format of your images and check the properties for your images. For this you can right click on the image and then select the properties look for the format and check that you have a valid program to run these on your computer. Each window contains its own photo viewer software and check that you have one version of such a program. If there is some problem in your windows program then try to recover. Check you VGA also so you have no problem in photo viewer.
Darrel R Gonzale
