Please Help Me To Fix The 80070422 Error When Updating Windows 10
When I try to update my Windows 10 version, I encounter an 80070422. The troubleshooter did not solve the problem, and all the Windows update services are running. What to do?
The following methods are helpful to fix the 80070422 error.
Method 1
a. Connect to the Internet
b. Open Control Panel.
c. Go to Network and Sharing Center.
d. Right-click on your Network.
e. Open Properties.
f. Uncheck the TCP/ IPv6 version.
g. Click on Ok.
h. Restart your device.
i. Try to update.
Method 2
a. Press Windows + R on your keyboard.
b. Type services.msc and press enter.
c. Right-click on Network List Service.
d. Click on Restart.
e. Restart your PC.
f. Try to update Windows
