Please Help Me To Fix The 80710092 PS3 Error.
I am getting an 80710092 PS3 error. The server is online, and I can access the Internet via XMB. I want this to fix as soon as possible. I hope this is not something serious.
You don’t have to worry as you can get rid of the 80710092 PS3 error easily.
Method 1
a. Open Settings.
b. Open Network Settings.
c. Look for Media Server Connection.
d. Disable it.
e. Try to connect to PS3.
Method 2
a. Open Settings
b. Go to Network Settings.
c. Open Internet Connection Settings.
d. Select the Custom Setting.
e. Look through the IP Address setting.
f. Select Manual.
g. Copy your settings to a notepad.
h. Change your settings to the following but do not save.
Primary DNS: 195.175.39.40
Secondary DNS: 195.175.39.39
i. Using the left d-pad, go through the Internet Connection Settings.
j. Under IP Address Setting, click on Automatic.
k. Click on do not set.
l. Click on Manual.
m. Make sure your Primary and Secondary DNS numbers match with the one given earlier.
n. Save your settings by scrolling through the right.
If these do not work, then you have some error with your internet connection/ router, or Sony is repairing something.
