Please help me to fix the Zoo Tycoon 2, 1628 failed to complete the installation error. I am getting the error when I am trying to install Zoo Tycoon 2 on my Windows 8 PC.
Please Help Me To Fix The Zoo Tycoon 2, 1628 Failed To Complete Installation Error
One of the following methods will help you to eliminate the Zoo Tycoon 2, 1628 failed to complete installation error.
Method 1
a. Open File Explorer.
b. Double-click on the C drive or the drive where you have your OS.
c. Go to Program Files.
d. Open Common Files.
e. Right-click on the InstallShield folder
f. Rename it to “InstallShield1.”
g. Now, try to install the game.
Method 2
a. Press Windows + X.
b. Open Task Manager.
c. Click on idriver.exe -> End task.
d. Similarly, click on the msiexec.exe -> End Task.
e. Restart your device.
f. Try to install the game.
