I cannot update or download apps from Google Play Store. I am getting a 924 error code. Restarting the phone and clearing the cache did not help. Please help me with different methods.
Please Help Me To Solve The 924 Error Code On Google Play Store.
There are different methods to solve the 924 error code –
Method 1
a. Open Settings
b. Open Battery & Performance or something related to it.
e. Click on Battery Optimization.
f. Open the Battery saver option.
g. Turn off the battery saver.
h. Try to update.
Method 2
a. Open Settings.
b. Go to Manage Apps/Apps.
c. Open Google Play Store from the list.
d. Click on Uninstall updates.
e. Restart your device after the process completes.
f. Try to run the update/ download.
Other methods to try –
a. If you have any antivirus app on your phone, uninstall them, and run the update/ download.
b. Remove your Google Account.
c. Add your account again.
d. The last option will be to factory reset your phone, but that will wipe away all the data.
