Please Help Me To Troubleshoot The 0x80300024 Error In Windows 10
I need to install Windows 10 on my PC that has Windows 7. I am stuck at an error with code 0x80300024. Please help me to troubleshoot the 0x80300024 error in Windows 10.
The error 0x80300024 can be solved by making a few adjustments to your hard-drive. Here are the steps for the same.
Method 1
a. Start your PC.
b. When the company logo appears, press F1 or F2 or Delete. You need to find out the key that will open your BIOS settings. It depends on the company.
c. Go to Boot configuration in the BIOS.
d. Make the hard-drive at the top of the order. The instructions will be given on the screen.
e. Save the changes.
f. Exit the BIOS.
g. Now, install Windows 10.
Method 2
Take a backup of all the data before this step.
a. Insert your installation media on PC, and restart your computer.
b. Choose to boot from installation media.
c. Make the necessary settings.
d. On the screen that asks the type of installation, select custom.
e. Open Drive options (advanced).
f. Select the drive to install the OS.
g. Click on Delete.
h. Click next.
i. Use this unallocated space to install windows by creating a partition.
