Zac Winnie
Posted on - 11/03/2020
I have a Windows 10 PC. My PC shuts down and restarts automatically nowadays. In the Event Viewer, I found the 41 critical Microsoft Windows kernel power system error. Please help.
Please Help Me To Troubleshoot The 41 Critical Microsoft Windows Kernel Power System Error
Method 1
a. Open Control Panel.
b. Change View by -> Large icons.
c. Open Power Options.
d. Open Change Plan Settings.
e. Change advanced power settings.
f. Match the settings with the image.
g. Match the settings with the image.
h. Apply -> Ok.
i. Restart your device.
Method 2
a. Open Advanced System Settings.
b. Open the Advanced Tab.
c. Open Settings.
d. Go to Startup and recovery.
e. Untick Automatically restart.
f. Save the changes.
g. Restart your device.
Method 3
a. Search device manager in the Windows search box.
b. Open it.
c. Expand Sound, video, and game controllers.
d. If you find duplicate drivers, right-click on any one of them.
e. Click on Disable.
f. Restart your device.
