erick
Posted on - 10/31/2011
I have been using the following keys to shift between various applications on my computer. Ctrl-1/Email; Ctrl-3/Contacts; Ctrl-4/Tasks and so on. I use Ctrl-2 to shift to Calendar from Email. When I do so, the navigation bar changes to Calendar but the view on the computer screen stays Email. Can you help my fix it?
Please help of the proper use of Microsoft Outlook shorcuts.
This problem is happening to you maybe because you kind of mixed some of the keyboard shortcuts from other applications on your computer. To better understand it, see below for some of Microsoft Office Outlook keyboard shortcuts.
For basic navigation:
CTRL + 1 – Switch to Mail
CTRL + 2 – Switch to Calendar
CTRL + 3 – Switch to Contacts
CTRL + 4 – Switch to Tasks
CTRL + 5 – Switch to Notes
CTRL + 6 – Switch to Folder List in Navigation Pane
CTRL + 7 – Switch to Shortcuts
CTRL + comma – Next item (with item open)
CTRL + period – Previous item (with item open)
CTRL + SHIFT + Tab or F6 – Switch between the Folder List and the main Outlook window
Tab – Move among the Outlook window, the Navigation Pane, and the Reading Pane
Arrow keys – Move around within the Navigation Pane
CTRL + Y – Go to a different folder
Plus or Minus sign on the numeric keypad – Expand/collapse a group (with a group selected) in the Navigation Pane
Left and right arrow keys – Collapse/expand a group in the e-mail message list
To see other keyboard shortcuts that you can use, you may visit Office | Keyboard shortcuts.
