Please Let Me Know The Windows Error 0xc0000007b Fix
I am unable to use any DirectX game as I am encountering the 0xc0000007b error. Updating the DirectX did not work. I have a Windows 10 PC. Please let me know the Windows error 0xc0000007b fix.
The 0xc0000007b often occurs when the app is not compatible with your computer architecture (32 bit or 64 bit). Here is the Windows error 0xc0000007b fix.
Method 1
a. Open Control panel.
b. Go to Programs.
c. Open the link to Turn Windows Features on or off.
d. Select .NET Framework 3.5, and click on, OK.
e. Restart your device.
f. Your error should be gone.
Method 2
a. Search xinput1_3.dll from DLLME on Google.
b. Download the file.
c. Extract the files.
d. Copy xinput1_3.dll file.
e. Go to C:\ Windows \ SysWOW64, and paste the file.
f. If prompted, replace the file.
g. Check for the error.
