anna scott
20 points
Posted on - 03/09/2012
Hi guys,
I am planning to buy new graphic card to my PC and I have 2 choices:
1. Foxconn Geforce NF9600GT- 512FOC- OC version.
2. EVGA Geforce 8800GT.
I need your help to find out which one is better.
So please suggest one.
Please suggest me a good graphic card
Hi Anna!
They are both good video cards but there is only one that is the best, I've been looking for answers and here is my take.
Manufacturer: |
Nvidia |
Series: |
GeForce 9 |
GPU: |
G94 |
Release Date: |
2008-02-21 |
Interface: |
PCI-E 2.0 x16 |
Core Clock: |
650Â MHz |
Shader Clock: |
1625Â MHz |
Memory Clock: |
900Â MHz (1800Â DDR) |
Memory Bandwidth: |
57.6Â GB/sec |
FLOPS: |
208Â GFLOPS |
Pixel Fill Rate: |
10400Â MPixels/sec |
Texture Fill Rate: |
20800Â MTexels/sec |
EVGA Geforce 8800GT
Manufacturer: |
Nvidia |
Series: |
GeForce 8 |
GPU: |
G92 |
Release Date: |
2007-10-29 |
Interface: |
PCI-E 2.0 x16 |
Core Clock: |
600Â MHz |
Shader Clock: |
1500Â MHz |
Memory Clock: |
Memory Bandwidth: |
57.6Â GB/sec |
FLOPS: |
336Â GFLOPS |
Pixel Fill Rate: |
9600Â MPixels/sec |
33600Â MTexels/sec |
As you can see in the specs you can already identify which one is the best. Speed wise 9600 GT is the fastest rendering card meanwhile if you want quality in graphics you can never go wrong with the 8800 GT because it has 112 shader compared to the 9600 GT that only have 64 shader.
Hope I've helped you with this problem, the final decision is for yours to take so pick wisely.
Good luck and have a good day!
I recommend EVGA Geforce 8800GT VGA card, Because I have IT. That is an awesome VGA card I ever Had. You can get amazing Gaming experience. Choose 2Gb DDR3 VGA card for latest games. But This VGA card generates more Heat. So Add some system fans as a solution!
