Please Suggest The Top 10 Mac Cleaner Software
I have a MacBook. I am using it for a few months. The junks are accumulating on my device, and it is tedious to clean the folders. What is the top 10 Mac cleaner software to ease my task? I won’t mind paying a small amount for good software.
Answered By 10 points N/A #344950
The top 10 Mac cleaner software that I will list here includes paid and free software. Open the link and download the one you like.
1. CleanMyMac X
This is one of the best Mac cleaner software. Additionally, it warns you about malicious software as well.
2. Disk Doctor – Get it in the Mac Store.
This app was awarded in 2013. It keeps a check on your computing power.
3. DiskCleanPro – Get it in the Mac Store.
This software has an amazing interface and a deep clean feature.
4. CCleaner for Mac
CCleaner is famous among Windows users, and now it is becoming among Mac users too. It has a friendly interface and does good cleaning work.
5. Gemini 2
You can keep this along with any other software on the list. This app will help you find and delete multiple copies of the same file in your system.
6. Onyx
With Onyx, you can do more than cleaning your system. If you are a tech geek, you will enjoy it. You will be able to change folder colors, play with cache, etc.
7. Drive Genius
One of the costliest Mac cleaner software around, but worth its price. Your Mac’s life will increase if you use this tool. It can help you recover lost data too.
8. Smart Mac Care
This app helps you clean hard disk as well as optimize your main memory (RAM). It has got a malware removal system also – a combination of different cleaner apps at a nominal price.
9. AppCleaner & Uninstaller
There are useless apps on our systems, and we are often unaware of it. This app helps you cleans those as well as the remains of the apps.
10. Sensei
A new app in the market with decent features. The interface gives an overview of how your resources are being used.
Note – All the apps on the list works on a specific Mac Version or higher.
