Please suggest which one to buy?
I have decided to purchase BenQ E2200HD monitor for my newly upgraded PC.
The PC is already running with Vista ultimate 64 bit and Windows XP dual booting. Want to now upgrade the 17" CRT to LCD. Considering the GPU has HDMI port I have selected E2200HD to get full HD native resolution. The PC will be mainly used for gaming, viewing the movie (DVD movie – non HD) and a Little bit of ms-office jobs.
Answered By 0 points N/A #178215
I do recommend you buy the BenQ E2200HD monitor.
It's an affordable Full HD 16:9 display (22 inch screen). It handles very well in terms of image quality, being especially designed to be used for widescreen formats, especially for games.
It supports a Full HD resolution of 1920×1080 pixels that can help productivity as well as offer more clarity in image rendering applications. It easily displays the extremes of light and dark shades, the text is sharp because of the high pixel count on the 16:9 format.
The viewing angles are the best of all, meaning that you can host a co-op split screen game with any friend because there will be no image quality deterioration, unlike other TN displays.
It also offers stereo speakers built in the monitor's case, and also the following connectivity ports: a VGA hub, one DVI-D port, one HDMI port, an audio line-in and one 3.5mm jack for any kind of headphone.
