emileekeila
Posted on - 03/22/2013
I have a problem hope you will going to help. I have Microsoft access file I want to send it via template email. How to send email using ms access send template email? I really don’t know how to ask. The point is I want to know how to send email using ms access send template email that’s all.
Please teach me in ms access send template email
I can give you two solutions.
1. You can send mdb file attached depend on the size that allowed to you. This depends mostly on the features available with your mailing system.
2. If your email system doesn’t allow you to send files with .mdb extension, then you can simply by pass the check by zipping it or changing it extension to .txt and attach it to the mail. But to use it on the other end (receiving end) need to change the extension back to .mdb.
Hope these solutions will work for your requirement.
