Please Tell Me About Sync Settings On Windows 10 Devices And How To Use Them?
I came to know about sync settings on Windows 10 devices. Please tell me what it is, and how can I use them?
About sync settings on Windows 10 devices – There is an option on the Windows 10 devices that helps you to personalize all your Windows devices with the same settings, such as the same themes, customization, browser options, etc. on all your Windows devices using your Microsoft account. In simple words, make changes in one device, and other devices will be automatically set with those settings.
How to use them? – Make a Microsoft account.
a. Open Settings.
b. Open Accounts.
c. If you have a local account, then click on Sign-in with a Microsoft Account.
d. Create a Microsoft Account or sign-in with the one you have.
e. After you have signed-in with Microsoft Account, go to the Accounts settings as shown above.
f. Go to Sync your Settings.
g. Turn on Sync Settings.
h. Turn on the Sync option for all the settings you want.
