Please tell me how to disable vpn password in ics?
I forgot my password ics and I am completely lost right now. Does anybody know know how to disable vpn password in ics? I am using Windows XP.
Please,help me!
Please,help me!
Hi Aimeemorgann,
Here is some steps on how to disable the VPN connection in ICS.
Fist goes to admin account that only you can disable the network services.
Second Go to START MENU click “CONTROL PANEL”
Third click twice “ NETWORK CONNECTIONS” there will pop up other window look ate the lower-half you will see the VPN connection set up.
Fourth highlight the VPN service you want to disable.
Fifth Click the “CHANGE SETTING OF THE CONNECTION” .
Six step Go to “NETWORKING” at the upper part of the window and CLICK “UNINSTALL”
Lastly SELECT “YES” to activate the disable of the VPN .
Hopefully my steps is solving your problem on how to disable your VPN.
Here is link so help you to retrieve your forgot password through WFI if you are directly activate on WIFI connection. http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
