Please tell me how can i change config.php writable?
Please tell me how I can make config.php writable and how I can change "mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/dbss/domains/dbss.kuheo.com/public_html/install/db_ctrl.php on line 185" ?<?php
if (eregi("db_ctrl.php",$_SERVER['PHP_SELF'])) {
   die();
 sql_connect($host, $user, $password, $db)
 sql_logout($id)
 sql_query($query, $id)
 sql_num_rows($res)
 sql_fetch_row(&$res, $nr=0)
 sql_fetch_object(&$res, $nr=0)
 sql_free_result($res)
 $dbtype:"MySQL;mSQL;PostgreSQL;PostgreSQL_local;ODBC;ODBC_Adabas;Interbase;Sybase"; */
class ResultSet {
   var $result;
   var $total_rows;
   var $fetched_rows;
   function set_result( $res ) {
       $this->result = $res;
   function get_result() {
       return $this->result;
   function set_total_rows( $rows ) {
       $this->total_rows = $rows;
   function get_total_rows() {
       return $this->total_rows;
   function set_fetched_rows( $rows ) {
       $this->fetched_rows = $rows;
   function get_fetched_rows() {
       return $this->fetched_rows;
   function increment_fetched_rows() {
       $this->fetched_rows = $this->fetched_rows + 1;
function sql_connect($host, $user, $password, $db)
global $dbtype;
switch ($dbtype) {
   case "MySQL":
       $dbi=@mysql_connect($host, $user, $password);
       if (!$dbi)
           return false;
       if (!mysql_select_db($db)) {
       return false;
       //mysql_query("CREATE DATABASE $db");
       //mysql_select_db($db);
       //include("includes/install.php");
       die();
       return $dbi;
   break;
   case "mSQL":
        $dbi=msql_connect($host);
        if (!msql_select_db($db)) {
       msql_query("CREATE DATABASE $db");
       msql_select_db($db);
       die();
    return $dbi;
   break;;
   case "PostgreSQL":
        $dbi=@pg_connect("host=$host user=$user password=$password port=5432 dbname=$db");
        return $dbi;
   break;;
   case "PostgreSQL_local":
        $dbi=@pg_connect("user=$user password=$password dbname=$db");
        return $dbi;
   break;;
   case "ODBC":
        $dbi=@odbc_connect($db,$user,$password);
        return $dbi;
   break;;
   case "ODBC_Adabas":
        $dbi=@odbc_connect($host.":".$db,$user,$password);
    return $dbi;
   break;;
   case "Interbase":
        $dbi=@ibase_connect($host.":".$db,$user,$password);
        return $dbi;
   break;;
   case "Sybase":
       $dbi=@sybase_connect($host, $user, $password);
   if (!sybase_select_db($db,$dbi)) {
       sybase_query("CREATE DATABASE $db",$dbi);
           sybase_select_db($db,$dbi);
       die();
   return $dbi;
   break;;
   default:
   break;;
function sql_logout($id)
global $dbtype;
switch ($dbtype) {
   case "MySQL":
       $dbi=@mysql_close($id);
       return $dbi;
   break;;
   case "mSQL":
        $dbi=@msql_close($id);
        return $dbi;
   break;;
   case "PostgreSQL":
        $dbi=@pg_close($id);
        return $dbi;
   break;;
   case "ODBC":
   case "ODBC_Adabas":
        $dbi=@odbc_close($id);
        return $dbi; Â
   break;;
   case "Interbase":
        $dbi=@ibase_close($id);
        return $dbi;
   break;;
   case "Sybase":
       $dbi=@sybase_close($id);
       return $dbi;
   break;;
   default:
   break;;
 * sql_query($query, $id)
 * executes an SQL statement, returns a result identifier
function sql_query($query, $id)
global $dbtype;
global $sql_debug;
$sql_debug = 0;
if($sql_debug) echo "SQL query: ".str_replace(",",", ",$query)."<BR>";
switch ($dbtype) {
   case "MySQL":
      // $res=@mysql_query($query, $id);
       if (!$res = mysql_query($query,$id)) {
           return false;
           //echo "error:".$query;exit();
       return $res;
   break;;
   case "mSQL":
       $res=@msql_query($query, $id);
       return $res;
   break;;
   case "PostgreSQL":
   $res=pg_exec($id,$query);
   $result_set = new ResultSet;
   $result_set->set_result( $res );
   $result_set->set_total_rows( sql_num_rows( $result_set ) );
   $result_set->set_fetched_rows( 0 );
       return $result_set;
   break;;
   case "ODBC":
   case "ODBC_Adabas":
       $res=@odbc_exec($id,$query);
       return $res;
   break;;
   case "Interbase":
       $res=@ibase_query($id,$query);
       return $res;
   break;;
   case "Sybase":
       $res=@sybase_query($query, $id);
       return $res;
   break;;
   default:
   break;;
 * sql_num_rows($res)
 * given a result identifier, returns the number of affected rows
function sql_num_rows($res)
global $dbtype;
switch ($dbtype) {
   case "MySQL":
       $rows=@mysql_num_rows($res);
       return $rows;
   break;;
   case "mSQL": Â
       $rows=msql_num_rows($res);
       return $rows;
   break;;
   case "PostgreSQL":
       $rows=pg_numrows( $res->get_result() );
       return $rows;
   break;;
   case "ODBC":
   case "ODBC_Adabas":
       $rows=odbc_num_rows($res);
       return $rows;
   break;;
   case "Interbase":
   echo "<BR>Error! PHP dosen't support ibase_numrows!<BR>";
       return $rows;
   break;;
   case "Sybase":
       $rows=sybase_num_rows($res);
       return $rows;
   break;;
   default:
   break;;
 * sql_fetch_row(&$res,$row)
 * given a result identifier, returns an array with the resulting row
 * Needs also a row number for compatibility with PostgreSQL
function sql_fetch_row(&$res, $nr=0)
global $dbtype,$q;
switch ($dbtype) {
   case "MySQL":
       $row = mysql_fetch_row($res);
       return $row;
   break;;
   case "mSQL":
       $row = msql_fetch_row($res);
       return $row;
   break;;
   case "PostgreSQL":
   if ( $res->get_total_rows() > $res->get_fetched_rows() ) {
       $row = pg_fetch_row($res->get_result(), $res->get_fetched_rows() );
       $res->increment_fetched_rows();
       return $row;
   } else {
       return false;
   break;;
   case "ODBC":
   case "ODBC_Adabas":
       $row = array();
       $cols = odbc_fetch_into($res, $nr, $row);
       return $row;
   break;;
   case "Interbase":
       $row = ibase_fetch_row($res);
       return $row;
   break;;
   case "Sybase":
       $row = sybase_fetch_row($res);
       return $row;
   break;;
   default:
   break;;
function sql_fetch_array(&$res, $nr=0)
global $dbtype;
switch ($dbtype) {
   case "MySQL":
       $row = mysql_fetch_array($res);
       return $row;
   break;;
function sql_fetch_object(&$res, $nr=0)
global $dbtype;
switch ($dbtype)
   case "MySQL":
       $row = mysql_fetch_object($res);
   if($row) return $row;
   else return false;
   break;;
   case "mSQL":
       $row = msql_fetch_object($res);
   else return false;
   break;;
   case "PostgreSQL":
   if( $res->get_total_rows() > $res->get_fetched_rows() ) {
       $row = pg_fetch_object( $res->get_result(), $res->get_fetched_rows() );
       else return false;
   } else {
       return false;
   break;;
   case "ODBC":
       $result = odbc_fetch_row($res, $nr);
   if(!$result) return false;
   $nf = odbc_num_fields($res); /* Field numbering starts at 1 */
       for($count=1; $count < $nf+1; $count++)
           $field_name = odbc_field_name($res, $count);
           $field_value = odbc_result($res, $field_name);
           $row->$field_name = $field_value;
       return $row;
   break;;
   case "ODBC_Adabas":
       $nf = count($result)+2; /* Field numbering starts at 1 */
   for($count=1; $count < $nf; $count++) {
       return $row;
   break;;
   case "Interbase":
       $orow = ibase_fetch_object($res);
   if($orow)
       $arow=get_object_vars($orow);
       while(list($name,$key)=each($arow))
       $name=strtolower($name);
       $row->$name=$key;
           return $row;
   }else return false;
   break;;
   case "Sybase":
       $row = sybase_fetch_object($res);
       return $row;
   break;;
/*** Function Free Result for function free the memory ***/
function sql_free_result($res) {
global $dbtype;
switch ($dbtype) {
   case "MySQL":
       $row = mysql_free_result($res);
       return $row;
   break;;
      case "mSQL":
       $row = msql_free_result($res);
       return $row;
   break;;
       case "PostgreSQL":
       $rows=pg_FreeResult( $res->get_result() );
       return $rows;
   break;;
   case "ODBC":
   case "ODBC_Adabas":
       $rows=odbc_free_result($res);
       return $rows;
   break;;
   case "Interbase":
       return $rows;
   break;;
   case "Sybase":
       $rows=sybase_free_result($res);
       return $rows;
   break;;
