Please Tell Me How To Open Pkg File In Windows 8? Use Of Different Soft-wares
Earlier I was using Windows 7 but now I have installed Windows 8 on my computer.So, I want to know, how to open pkg file in Windows 8?
Follow these steps
>First download and install “Easy 7-Zip.”
>The installation will be followed as:
> Click on XAR/PKG file & open XAR/PKG.
Now, you will see file folders within the XAR/PKG file then, use button extract to extract the XAR/PKG file.
The “PKG” file (.pkg) is a file format or extension normally used in Mac OS X operating system. The file normally contains installer scripts used by a variety of Macintosh programs for installation purposes. There are also times PKG files are used to update NeXT installer packages. This file format was developed to help software designers create uniform installer applications.
It allows the easy and seamless installation of software applications and software updates. If you have several PKG files that you need to convert to ISO format, you can download AnyToISO. This software allows you to extract and convert any disc image to ISO. It also allows you to create ISO files from CDs, DVDs, Blu-ray discs, and folders.
Among the supported file formats include:
Notifications
