Plug-in error launching with a compatible app
Posted on - 08/19/2014
Hi there,
I want to install a plug-in on my laptop for iMovie and this error appears. On the website it says that is compatible with my OS and it should work without a problem. Can anyone help me please to fix this error ? What is wrong with my laptop ?
Regards experts !
Incompatible Plugin
The plugin “Twirl.bundle” cannot be loaded, because it isn’t designed to run on this computer. If you don’t need this program, remove it from your plugins folder (in Library>iMovie)
