Plug in installation and information
I cannot decide on the best plug in available for installation. I did a search in Google and it gave me a lot of recommended plug ins. Can you tell me which of these is the best?
Apple QuickTime, Real player, Adobe Reader, Windows Media Player, Internet Pictures Corporation or IPIX, Adobe Flash Player, Adobe Shockwave. I just wanted my computer to be as up to date as its supposed to be.
Thanks!
Answered By 0 points N/A #118586
You arise a very interesting question on this platform well there are so many plug-ins will be shown while in searching with the Google and those plug-ins might be confuse you which you should use and to which you should have to avoid while you don't know what is perfect plug-in for your computer.
Well i already try to search on Google and it makes me confuse then i realize that i should use windows update and let windows defaults to check the proper and perfect plug in for my computer so i did start windows updating and my computer automatically updated and installed the best plug-in for my computer.
So you should also try to update your windows by windows update option hope this will work.
