Plugging a high-speed device to a non high-speed port
I am building my own PC. When I purchased an Asus Motherboard P4C800E-Delux and put it on my PC, I started receiving issues when trying to connect an external drive to any of my USB ports. The external drive cannot be read and the error says I am plugging a high-speed device to a non high-speed port. All the ports on my computer are 2.0 variant. My printer works fine with it. What is this error and how can I fix it? How can I turn off the balloon message?
Best Answer by lee hung
Answered By 75 points N/A #115006
Hello Joseph Price,
It seems like the external drive requires ports that perform at a high speed as compared to the ones that you are currently using and therefore you will need to get com ports that are high performance than the 2.0 variant and install them so that they can be used to connect the external hard drive.
You may successfully connect the external hard drive to the current 2.0 variant ports but the problem is the performance will be so slow. Processes like file transfer will be taking a whole lot of time to finish and therefore you should just get high speed ports to use for the external hard drive.
Hope this helps.
__
Regards
Lee Hung
Answered By 15 points N/A #115007
Are you using a USB 3.0 external drive? If so, then this may be the cause of the problem. You motherboard is old and does not have the USB 3.0 controllers. While this may not be a big problem, the major drawback is that your device won't be able to reach its designed optimal speed. It is also likely that you have a USB 2.0 external drive and you are plugging into your front USB ports (front chassis). Some older motherboards have USB 1.1 that uses the front ports. If you use these ports the same error will come up. Try using the ports at the back instead.
