Plugin for mozilla flash player android stopped working.
Plugin for mozilla flash player android stopped working. The plug in helps to established the game properly specially on web browsers such as Mozilla firefox, opera and google chrome. How would I be able to view the youtube page or play y8.com game in my android mobile phone if the plug in is not working properly? Help me fix this problem. Thank you.
Best Answer by Nicke Baker
Answered By 0 points N/A #181303
Hello Jayden,
You will just need to install another plugin to resolve that issue, for the one you have right now seems to be having issues. Just open your Firefox browser and then go to Tools, and then Add ons. Make sure that you have connection to the internet and then search for the plugin, and then install it.
Nicke
Answered By 60 points N/A #181304
Hi Jayden Horribol,
As I searched Google for possible solution, I have seen a forum that discuss about this situation. I think that many users also encounter this problem. Kindly click the link below for your reference.
Does Firefox for mobile (on android) support adobe flash player?
Hope that it would help you.
Answered By 10 points N/A #181301
I am sorry to inform you that Firefox on android didn’t support plugin’s like Flash. It was in the news that they are working on the flash but till now there is no update for flash. So, you have to compromise on this and use another browser for using Flash. Check this link for more information.
Thank you
