Hi
I bought a toshiba e740 pocket pc.I have a wireless internet in my home.But i am not able to connect as it gives error:unable to connect with current settings.pls resolve this.thanks in advance.
Pocket pc gives error while connecting to internet
Dear,
I have understood your problem and I have a solution for you. This will resolve the problem completely.
For resolving this problem you have to follow these steps,
First of all download the manual of Toshiba from the given link and it will surely help you to get the key points.
The link is,
http://mikechannon.net/PDF%20Manuals/Toshiba/Toshiba_e740_User_Manual_EN.pdf
In this link you can get the detailed information of the Toshiba and its current and upcoming features and the requirements to get benefits from these update files and versions. This will increase your knowledge about the Toshiba models also.
Hope you got the answer.
Best of luck for your future.
