Pogoplug Drive for Mac: (error code -43).
I've just got my Pogoplug Pro and attached my LaCie Rugged 500gb drive. After downloading the MAC software, I opened the Pogoplug icon on my desktop and instead of seeing my drive, I saw a broken alias file named 'LaCie Rugged FW/USB'. When I clicked the broken alias file, I got the error '(error code -43)' and another error saying 'the application cannot be found'.
What should I do with this?
Best Answer by enlighted
Answered By 0 points N/A #86487
To fix this error you will need to do these:
  • Download software updates: it updates the drivers that control your computer.
  • Download Windows code 43 error fix: helps to fix the error.
  • Sometimes a Window code error may be due to a virus or a spyware, so, it is suggested to run a remover tool like the step mentioned below:
  • Download spyware remover: scans and removes all adware, viruses or spyware from your PC.
  • Click the link
  • A new window should appear with lots of options, Click Open and Run this program from its current location or save it on a disk.
This will surely help you.
Answered By 0 points N/A #86488
I got a lot of help from here. I also faced this problem many times but I fixed it. I also got some help from this article.
Hope it works for you also.
