Point security systems air notifier isn’t notifying correctly
Hello, I am using  Point security systems for my home and office security. It is a cool security system. It works as my housekeeper. But suddenly my  Point security systems air notifier isn't notifying correctly. Anyone here who is using this software? Anyone here who can help me with this?
Answered By 590495 points N/A #186546
If you are referring to Point Security Home and Commercial Security Systems, I guess to fix that problem with your air notifier you should visit the site, Point Security Home and Commercial Security Systems, and then contact support. There is not much help available on the site for users that are having issues with their device.
You can’t even find the usual Frequently Asked Questions or FAQs on the site. I mean, I tried searching the site for their FAQs and I found it but unfortunately, they didn’t put anything into it. The FAQ section or page is completely blank. I guess, since you are talking about the security device they installed into your home or maybe in your office, the best way to deal with it is to ask them personally.
Additionally, Point Security is a local leader in commercial surveillance systems and home security alarm systems for San Antonio, Austin, and neighboring areas. They specialize in servicing, installation, and monitoring of customizable security solutions.
