Pointing device drivers 64 bit (Synaptics) for Lenovo V200 with Windows Vista
Johnny L 10 points N/APosted on - 03/11/2013
I need a package of Pointing device drivers 64 bit (Synaptics) for Lenovo V200 with Windows Vista that will detect & configure pointing devices. Please advice me on where to get such package of driver, also do the needful for providing me a free download link and Installation instructions. Thanks
Hi Johnny,
let me tell how to get 64 bit(Synaptics) for your Lenovo V200 by using  your device manager right click on device and go for search device driver automatically but before that you must have working internet connection and you get what you want easily.But if you do not get your driver than one more way to get that is go for your latest update of your opporating system and install them this can also help you.
Hello JohnnyÂ
You can download the synaptics drivers for Windows Vista Operating System for Lenovo V200 by going to the Lenovo support website
I have found those drivers for you. Please click on this link, then according to your Operating System, you can download and install the Drivers. Here is the Link – Drivers for Lenovo V200
Here you can also download and view the installation and uninstallation instructions.Â
I hope this would help
If you need a driver or set of drivers for your laptop, you can always find it in the manufacturer’s website of your device. If you have a Lenovo laptop, go to Lenovo Technical Support then search for your laptop model. On the other hand, if your model is no longer available, it is possible that your laptop is very old and Lenovo already removed the drivers.
Lenovo 3000 V200 notebook
In this case, your best option to downloading the drivers is from another website. If you need drivers for your Lenovo V200 laptop, go to Lenovo V200 Notebook and get the drivers. Select your correct operating system to display only the drivers for your laptop. The drivers are available for Windows 2000, Windows XP, Windows Vista, Windows 7, and Windows 8.x.
1....
