onam ophir
40 points
Posted on - 02/21/2013
Error Message had found in Windows Media Player.
Windows Media Player cannot perform the request action at this time.
I cannot understand how to solve this problem. I wait for ideas of the expert for this…
Points to Consider when using DTS- Connect
Its not necessary to use window media player, While playing video's or audio , You can try out other 3rd party unpaid software, With good interface and good video and audio quality, Now solution to your window media player problem is to troubleshoot, few things, like check file type,is it compatible with media player ? perform virus scan. If the problem is still there look for another software like, VLC, etc.
Here is the link for best unpaid media player.
https://en.softonic.com/s/best-music-player-of-2012/windows-7
Thanks
