Dutchee
220 points
Posted on - 06/12/2011
Hi Guys,
I have a problem on my computer. When every time I'm going to shutdown or restart my computer there's a pop up message on my screen. It's a yahoomessenger.exe, that needs to click end now. When I'm going to shutdown my pc, first I'm going to closed all the programs and files. But it makes me wonder why there's a pop up message when I press shutdown. What is the reason of that pop up message? Is it a virus? How can I remove that pop up message?
Please help me guys thanks in advance.
Yahoomessenger.exe popups when restarting my pc
Hi there, I'm Mark
It seems to me that there is something wrong with your Yahoo! Messenger, what I can advise you to uninstall first your Yahoo Messenger try shutting down again and see if the error message still appears and if it doesn't install Yahoo Messenger again. Here's how you can do it:
First make sure you have a copy of your Yahoo Messenger installation.
Go to Start and click Control Panel, then choose Add/ Remove Programs.
Once there, find your Yahoo Messenger installation on the list.
Right click the Yahoo messenger installation and click Uninstall.
Follow the instructions to proceed.
After testing to see if the error is still there after installation, install your Yahoo Messenger again if you want.
So there you have it, I hope this solves your issue.
Hello Dutchee,
Try to log out first, or right click the icon on the right side of your task bar. Click Sign out and/or Exit. If it doesn't work try to reinstall Yahoo Messenger.
Hope this helped you.
I will help you to eliminate the problem and keep you cool. The Yahoo Messenger popping up at startup and shutdown is happening due to its presence at the start up. Press Window + R key. It will bring a window. Write there, msconfig. Then another window will come. Choose startup tab and uncheck yahoo messenger. Click ok or apply. Restart your pc and it's gone.
