Marssh
110 points
Posted on - 05/29/2011
I recently started receiving this prompt that says I have to install BPDSoftware. It always shows up at start up and then won’t go away. When I press OK to let the program install itself then it asks for a CD. I tried scanning with my Kaspersky Antivirus but there were no infections found.
This is really annoying at every start up and the only way I can end this is by going to the task manager and ending the task. Â I am using Windows 7 Home Premium and a Compaq CQ61Â Laptop. Desperately need my old system back so please help.
Pop up requesting to Install BPDSoftware on startup
Hello Marssh,
I have read your problem just now and also have a good and easy solution of this problem. You have mentioned that you want not to appear this dialog box. Installing windows can be the easy solution. But I will discuss the alternative.
You should be very technical and careful to do this :
Click on start menu and select run program.
Type msconfig there and press enter. (System configuration tools will be opened).
Go to start up tab.
Find the problem application by startup name or Manufacturer or command as you like.
Uncheck the check box and restart windows.
Hope your problem has been solved.
