Hi experts,
For patching beta, I was in need to start my computer on a whole night. In the morning, I found an error message, telling to install the latest C++ and I got the same done. Then, another error message that uninstall Microsoft frame network .NET popped up. I also got the same uninstall, but still, I am not in a position to work on it.
Do you have any idea regarding this issue? Please help me.
Thanks in advance.
Popping up error message that uninstalls Microsoft frame network .NET
It looks like you installed an unregistered copy of .NET framework on your computer. You installed C++ on your computer which detected that you have an unregistered copy of .NET framework. That is the reason why you are getting the message to uninstall .NET framework. To solve this problem follow the steps below:
Go to Control Panel on your computer and uninstall the .NET framework.
Then go to the official website of Microsoft and download the version of .NET framework that is supported by your computer.
Install the framework and restart your computer.
Now try to patch the beta and your problem will be solved.
