wreighzzah
Posted on - 09/22/2011
My video skips when played. It was recorded through my Sony DCR-dvd 605  Mini DVD, I can easily play it on regular DVD player but not on GOM software on my Acer laptop. And a pop up message comes up "cannot play the media file in normal process" What are codecs?
What does it mean?
Error :Â
Cannot play the media file in normal process.
You dont have necessary codec to play
Please click "Find Codec" button to right side.
Codec Finder will help you to install Codec.
miao5656
Popup message on Gom player
Find codec message is giving gom player when it finds the appropriate codec is not available. There are some tips to solve this problem:
a)  If you hit the find codec button then it will take to homepage of gom player and shows the codec is not find
b)  To solve that you have install .dat or .vob  supported codec which gom player does not have.
c)  You can install other player like media player classic , it can solve the problem
d)  Use powerdvd or any types of DVD player to play DVD.
e) Â KM player is a powerful player in which you can play any kind of files.
