alwyn white
20 points
Posted on - 03/28/2012
My pc is recently going through a troublesome issue. I use avast free anti-virus latest upgrade and it is serving fine. Recently all of the portable devices I plug in are shown as affected or there is this message says threats found. No matter how many times I scan it there is no use. Is that a software problem or a hardware problem. I need to know for sure others wise I do not which way to go.
Please someone inform me as quickly as possible.
Alway White
Portable devices are showing as affected or threats found
Seek and destroy any or all viruses and malwares threatening not only your computer system but your portable devices as well like your mobile phones, external hard drives, and even USB flash drives. You can even get antivirus for your USB ports to make sure that it is safe from any infections. There are many 3rdparty antivirus downloads that you can get online for these devices. One particular website which is http://www.softpedia.com/get/PORTABLE-SOFTWARE/Antivirus—Antispyware/Windows-Portable-Applications-iPMS.shtml#downloadoffers iPMS (iSergiwa Portable Malware Scanner version 2.1.0.2) download for free. This application or program will help you remove malware not only from your portable hard drive, but even from your floppy discs and USB Flash Drives.Â
