I want to buy a 32 GB pendrive and for this I need to know which company or brand will be lot faster. So far I have used different brands of pendrives and I am not satisfied with their output. Kindly someone inform me of the brand which will be faster for sure. Should someone know of the better ones kindly let me know.
Aldrin Richards
Portable drive with compatible speed and size info
Hi Aldrin Richards,
Well, there are a really a lot of popular and renown pen drives out there; thus, it is really hard to choose the best pen drive among the other pen drives. Especially when all of these brands claim to be the best, it makes it harder for one to choose the best. Considering the fact that there a lot of good brand, I suggest you weigh them through their prices. Well, if you really want brand names, then I suggest you use brands like Corsair, Kingston, Transcend, Samsung, LG, SanDisk, Imation, and many others. There are really a lot to choose from. Well, if you want more information, then refer to this link.
https://www.laptopmag.com/articles/best-cheap-usb-flash-drives
>>Mathew Joni<<
