Portable Modem with Sim Card Reader Capability
I bought a Dekart  SIM card reader that I thought was also GSM modem but was wrong. Does anybody know where I could get a portable modem with sim reader as added feature? I have tried searching over the net, and into online stores like RadioShack, Bestbuy and others but they don’t seem to carry it. Thanks in advance for your help extended.
Answered By 0 points N/A #148133
Depending on your needs i would recommend ProLink PHS100 3.5G USB HSDPA Modem. It comes with many features including,
  1. Sending & receiving text messages.
  2. Transmission of up-to 3.6 Mbps.
  3. Plug & Play mechanism that automatically installs whenever connected to a PC.
You can buy the modem online through their online store, the link i will give you for easier reference,
http://m.1mobile.com/com.bindapp.video.ais00000003710.html
Below is a screenshot of the modem,
Hope that helps.
