Rhina
20 points
Posted on - 09/24/2011
I have created a portable Microsoft Office Word under the VMWare application running Windows XP.
When I tried using the created Microsoft Office Word application portable, I have encountered this problem when running in Windows 7.
The portable application works in Vista and XP.
I need the portable application in Windows 7, please help.
Winword.exe has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
Jhnasrin
5 points
Portable MS Word Created in VM Ware doesn’t work in Windows 7
Hey Raina.
You have installed Windows 7 in your PC, and there your required system will not supported.
You can try same soft, but another upgrading version to use. See your installed programs website.
I have some versions for Windows 7 supported like WN 3.02 / WN 5.00 / 6.09 etc.
There you can do install WN Manager from your Windows original disk and other from soft manager.
Go> the drive where your windows install > select the MS Word there find the Word support and paste the exe file on the basis your apps real exe file.
(when show replace the file click there yes) Restart you PC after scanning your system you can use it.
Thanks
