Bricen
Posted on - 11/08/2011
There’s a great deal of game time that I don’t like anymore since I’ve already played and grew tired of them such Plants vs. Zombies and also Tiger Wood 12 and so forth. I’m certain that I don’t want to play these games anymore so I’m thinking if there is a possibility for developers to consider of thinking of having game syncs since doing so would save synced across future gadgets in the likes of Ipad 2 and iPHone 4s?
Possibility of having game syncs
Hello Bricen,
If you do not need to play the game again then, I agree with you that you should synchronize the games, but I will advice that you should not use a cheating device so as to alter the game. The quick fix that I will recommend for the games that you are fed up playing is to delete the original saved file of the game, and then start a completely fresh game.
You can now start playing the new game but make sure you do not use a device that is used for cheating because it may cause the syncing to have problems. If you have to use some cheating device which I still do not recommend then do so after you are done with the synchronization of the game.
__
Regards
Clair Charles
