Possibility that in Il2 Steam history fx mod be saved
40 points
Posted on - 12/09/2012
I'm getting a system crash randomly while playing IL-2 Sturmovik: Cliffs of Dover on Steam. I bet it's about the effects. Is there any possibility that in Il2 Steam history fx mod be saved so I could eliminate and fix the cause of the problem? Do you have any possible idea why this is happening?
