Hi there,
I am an assistant data entry worker and I heavily use the default notepad to take down any notes that the supervisor that may tell us to take note off. I have been wondering if there is such a script or plugin that will apply auto save to notepad software , as it is a vital function in my line of work
Thank you.
Possible to have auto save to notepad software
Hi Joseph,
I know you are still confused on what you are doing,and here will i suggest or advise to you. Yes of course it has. Why not use a free program like the EditPad Lite for all your text documents. Try to go to this link http://www.editpadlite.com/. As you see EditPad is a general-purpose text editor,designed to be small and compact, yet offers all the functionality you expect from a basic text editor connector to your files. I know that it just depend on you but all I can say is there's no wrong in trying. With this you can open and make as many files as you can.
