Dear experts,
I am a Network Administrator and I have to install any application (software) on Client PCs which are located at various Geographical locations. Is this possible to Save Setup of Applications on the internet and install them from the internet? What is the way of hosting windows applications on the internet?
Is this possible to hosting windows applications on internet
Hello Kidd,
Yes, it is absolutely possible to save your applications on the internet. What you need is you must have a virtual server on the internet. And then you can access from anywhere and install them easily to any computer you want.
Google Drive Virtual Server
And the Other alternative solution is to have an account on the free storage server and put your software there. DROPBOX is a one fine storage place you can find on the Internet. It also gives you lots of space freely available.
SkyDrive is another storage website which allows you to store files up to 7 GB free.
SkyDrive
Thank you.
Rubi Sharlene
