hansmith
10 points
Posted on - 10/31/2011
Hi All,
I’m using iBiz 3 through remote access from the main server; I used it on my computer to track activities on server. I want to have a standalone, is it possible for me to install it with this set up without getting any possible conflicts on connections? Any help and Thanks
lee hung
75 points
Is that possible to install this ?!
Hello Hansmith,
I guess in your case you will need to obtain the ibiz standalone version so that it can be able to run on the stand alone computer as you want.
But you can still have the ibiz 3 stand alone and the ibiz server running on the same computer. I will however recommend that you use separate accounts when running the two applications so as to avoid conflicts that may arise as a result of having them installed on the same computer.
Hope this helps.
__
Regards
Lee Hung
I like the ibiz 4 software it has multiply task types..you may install a standalone version of the ibiz like the ibiz professional version 4.1.4 server and client versions this software is good in business and it's easy to setup just download illegal software from the web it's better to purchase the original software.
