Possible reasons for error message of unregistered model on my pc studio
What could be the possible reasons of the error message of unregistered model on my pc studio when I connect my Samsung mobile handset to synchronize some files?
As you haven't mentioned the specific error message or the specific problem you are facing when you are trying to synchronize your phone with the PC I'll suggest you some ways to overcome common error messages.
* If you haven't installed the required programs (MS Outlook 2003 and Internet Explorer 5 at least) which needs for functioning of the PC studio the application won't work properly.
* If you are getting an error message where you can't sync your phone try to run the program as administrator. If it doesn't work check whether all program utilities has been installed properly.
* If you are getting an error message asking to register the software it means the trial that has been offered to you is over. You'll have to register the product online to continue using the application.
* There may be some other errors too occur when you sync and transfer unsupported data formats via PC studio. Try to download and install the full version of the software which will give fewer errors.
