Is that possible to run Skyrim with an intel i3 2310m with integrated graphics and 4gigs of ddr3?
It is not bothered about running it on max specs, Wondering if it would run at all. It is not gaming computer but the graphics chip is cool. It's surprised me.
If anyone know about it please tell me details.
Lamnar
Is that possible to run Skyrim with an intel i3 2310m?
yes you can try
to install Skyrim you need to have following hardware requirements
Celeron E3300 Dual-Core 2.5GHz or higher ( your computer processor is 100% okay to play game )
Nvidia GFX Card
GeForce GT 420
RAM(Memory) 4 GB
Hard Disk Space 10 GB
Direct X 9
but according to your details you should be able to play game with your computer. before that i need to confirm whether your onboard VGA shares memory from your RAM or not ? if it is sharing you may not able to play. but you can install it and play. for an example I have installed Duke Nukem 3 in a laptop with onboard intel HD Graphic card ( 1748mb shared from memory ). 4GB RAM, and intel Core i3 specs. game worked. so you better try and see
thanks
