Is it possible to trace any msn and to get an IP through this? It seems to me there is one contact in my list trying to be another person time to time, and I need to check if there is two different people or it is same person.
Therefore, I need to get and compare IP addresses (through msn). Can you advice how to do that?
Is that possible to trace any msn?
Hello Joby,
If you want to check the IP address of a contact on MSN, I have a solution for you. The first thing to do is click on Start then hit Run and type “cmd” to bring up the command prompt. Once at the command prompt type “netstat” and you should see a list of IP addresses. If you want to see a particular persons IP address, you need to send them a file at least 1mb or larger and the IP will show up in netstat.
Hope this helps.
