Possible way to do TTF size reduce on larger files
Hi, I have created some fonts over 80 encodes those fits in true type TTF files. But those files are larger than 560 kB. I have to reduce its size. Is there any possible way to do TTF size reduce on those files?
Best Answer by Freddie C Slater
Answered By 40 points N/A #151438
Hi Goldman,
You can try this method of resizing your font file,
1. Download FontForge
2. Install and Run it.
3. Go to Edit
4. Then Select
5. Click Select All
6. Go to Element
7. Then choose Transformations
8. Click Transform
9. On the "Transform" menu, choose your desire size percentage for your fonts. Just make sure to check all the boxes
10. Click OK
Rendering process starts.
11. Go to File
12. Generate fonts. Make sure to change the file name when generating, this is to keep your original file.
13. Click OK.
Hope this will help,
Thanks
Answered By 0 points N/A #151439
Dear user,
For doing TTF size reduce, you need to convert everything in your data to straight lines. Now, you will see some fine rough texture, now, removal of your data for curves will make your file smaller and will not affect the results much.
To convert to straight lines, you have to select your data, then right click on it, select Retract BCPs.
Hope this will help you.
Thank you.
