Possible way for changing the postmaster account
Hi! I just need to ask if there’s a way for me to change the postmaster accounts when you’re using a hosted environment; this has been concerning me for quite a while now.
You see, if a user sends a mail and then get a NDR, the Postmaster account will be generated from the master domain so that would have to be ABC.com and the hosted domain would be XYZ.com. I was wondering if there’s a way for the XYZ.com generate on its own.
I hope you can help me.
Thank you.
