Hi people! I was surfing the net when I came across this site telling about ring out tone, I didn't know what it was until I read the description of it. It kind of given me interest in personalizing the ring when I will call any of my contacts. Is there a way I can change the ring out tone to my own choice of ring? Help will highly be appreciated, thanks!
Possible way to personalize the Ring out Tone
Hi there Acilis,
Your problem is not really that hard to solve. All we need to know is what model of phone are you using? Anyway, if you're using android phones, you can do this easily by following this instructions:
Go to Contacts > Choose which Contact you want to personalized a ringtone with > Tap "Menu" button > Click on Options
You'll then see a text saying "Ringtone" default > click Ringtone and the whole list of your audio will appear which you can choose what ringtone you want to set this contact with.
Click the chosen ringtone > Tap "Save" > then exit
A video tutorial can be found in here.
I hope you you'll sort your problem with this tutorial.
Waall Mike
