PostgreSQL installation failure data directory error
I am a pgsql user. I had a problem with installing postgres8.1, the error occurs at the 4th step of installation. The error stated is as follows:
Data directory error:Â The specified data directory is not empty
If you have an existing database with the same major version number, you do not need to initialize a database cluster. If you have an existing database with the same major version you need to backup your old database and create a new one.
I am wondering why this error message appeared while I am on installation process. Whenever I install by enabling the initialize database cluster, then the next three steps of installation procedure is not shown. It goes directly to start installation, after some time a fatal error arises and it shows a message account not matching and all of a sudden rolls back the process.
What I did was to try with lots of account names and lot of super user names. What might be the cause of this message? Please help me find solution.
Thank you.
![](https://www.techyv.com/sites/default/files/Data-directory-error.jpg)
The specified data directory is not empty.
If you have an existing database with a different major version you need to backup your old database and create a new one.
